I'd like a gear stick?
Hi. I currently own a z32 twin turbo fairlady. I'm pondering about replacing the auto box with a manual, obviously having to fit a flywheel, clutch, master and slave cylinder, pedal box and gear stick + trims. I am a motor technician by trade and unafraid of manual labour! Cost is a slight issue but i really hate P R N D 2 1 !!!! Im certain this has been done before, does anyone have an idea on cost for the project and any other parts that i would require? Any suggestoins are greatly appreciated/ Thanks
Cost is usually £1000-£1500 depending on where you source the parts, and if your undertaking all the labour yourself.
There is a brief guide here : http://www.z1motorsports.com/PDFs/Autoto5spconversion.pdf
and list of parts required :
Manual Gearbox
Driveshaft
Flywheel (all the bolts)
Pressure Plate
Clutch Disk
Pedals (CLutch and Break)
Clutch Master Cylinder
Clutch Slave Cylinder
Clutch Booster
Clutch Vacuum Hoses
Check Valve
Vacuum Tanks (2 of them)
Clutch Release bearing
Shifter + Shifter Bushing
Holder Bracket
Lower Dust Boot
Upper Dust Boot
Manaul Shift Boot
Shift Knob
Occasionaly AndyZ or MJP sell the whole kit required for around the £700 mark, may worth contacting them (check traders section)
