After having a new clutch fitted - somebody had not put the cable back in correctly near the gearbox. As i found out by picking up half a ripped wire that had been dragging on the ground.
Now, I have no reversing lights - Any idea what I need to wire to where?
I think they come on for half a second as you select reverse but then immediately go off.
think you may struggle to reconnect it - I can't remember exactly where the switch is, but when I did my clutch I remember it was tight!! Soemone may know whether it's possible to reach from the top?? Other possibility I guess would be to put a new reverse switch in from above and re-wire?
Just re-reading your post, it's strange that the lights come on at all... afaik it's a make or break switch - no relays or anything :confused:
Rich
The switch is located on the drivers side of the gearbox IIRC. It's a pain to replace i'm afraid, mine waited till the gearbox came out :(
Vijay
I dont think its the switch - I posted a while ago about this.
underneath the gearbox I had 2 connectors dangling in the road.
one had one end of a connector on and a bit of wire.
I dont know if one has come away from the switch on the gearbox or what?
but the other needs a cable going somewhere?
