Im in the middle of fitting indiglo dials. so far so good apart from the needles.
do these just pull off - I dont wanna break them?????
Ive pulled a bit but when the temp needle came out it came out with the pin attached still? Ive pushed it back in - is this is - all I have to do is pull on needles??
ALSO . . . .
Do i remove the main bulbs when fitting indiglo dials??
Do I put the indiglo dial leads through the holes where the bulbs used to be?
u drill holes in the top of the plastic for the indiglo leads,u should never remove the needles on any of the gauges to fit the indiglos just pull them over the top little tricky but works and i left my original bulbs in place
Oh, so removing the needles was a bad idea. . . .
