Urgent Help Needed!!!!!!!!!!!
Trying to install boost gauge,
as you can see in pic,
clear plastic pipe provided with gauge is
much narrower than the other pipes nearby,
which i think are the pipes to T into.
What should I do???? :confused:
HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!
vbgarage.php?do=getimage&id=1896
Mine is teed into the pipe to the right of the balance bar and you already have a T piece here :confused: Not sure what this T is connected to... Did your gauge not come with a T Piece?
Steve :)
'93 UK TT Manual
nope it did not, and I don't know where that goes either lol, oh bugga.
Hoping Mantav8 can help when online, as I got em from him
Steve :)
Ok that pipe thats T'd in there
just goes round and is T'd into the pipe
that spans between my 2 dump valves.
I didn't do them so don't know why its there.
This is buggin me now, can i get a T joint wiv dif size ends????
vbgarage.php?do=getimage&id=1719
My boost gauge uses the same tube you've got and it fits inside the T piece. I've siliconed and taped it in place to ensure there are no leaks and it stays put. Has been fine for well over a year so far!
Steve :)
'93 UK TT Manual
I used some heat shrink on mine - has worked flawlessly.
Same as Cybernet - the boost gauge tube sits inside of the T, the heat shrink holds it there / makes the seal.
LOL - I considered using heat shrink but my ineptness and visions of a melted tube steered me to the quick and dirty route :D
Steve :)
'93 UK TT Manual
Cheers guys, I'm off to the car shop lol
heat shrink?? just use hair dryer on it or heat gun??
T it off the existing sender pipe, which has a much smaller bore. It's under the little rectangular black box in the top LH corner of your picture, beside what looks like your alarm siren.
Steve :)
:rofl: - it was simply too great an urge to resist - playing with fire! I blame it on my mis-spent, pyromaniacal youth...
Thank you ALL for your help, have sorted it
Heat shrink and lecy tape for good measure lol
Not pretty, but will do for now, and I know now
I'm not on safey made LOL.
next the water temp and oil pressure gauges "GULP!!!"
Cheers again
Bandit...Out...
O dear!LOL! :D easy way to plumb em' mate is a couple of adapters off Chris,
give him a shout and he'll sort you out! ;)
