reverse lights packed up
can anyone help,reverse lights packed up,bulbs fine,not sure what fuse is responsible whether in footwell or under bonnet,no imformation on fuse covers relates to reverse lights,also anyone know a small japenese man if it is a fuse,to fit it ,bloody tight down there,thanks fellas
Craig
Reverse light fuse : located in drivers footwell, bottom row 3rd from right marked A/T
Jeff TT
Mine have done the same but it's not an MOT faliure so don't panic! It's normally caused by the reverse switch in the gear box. If when in reverse you shove the stick hard back and hold it they may come on!
