When in OD as I slow down, When the RPM goes down to about 1500/1000 it starts to judder a bit. But if I turn the OD off and slow down no judder at all. My car has allways done this. Any ideas ??????????????? or is this just another zed thing!!!!
I had this turned out to be the prop shaft bearing changed friday.
Hope that is not ££££££££££££££ to sort out.
still got the problem. But no clues off you lot yet ! :o :dance:
have you done an ecu diag
Have seen something similar on a Z where the autobox oil level was low, with OD on the car would judder and almost stall while slowing down but with OD off it was ok.
