T P S probs ?
Hi all ,
just tried to set my tps again , when i set it 0.45 v the revs are up to 2500rpm so to get the rpm down to 900-1000 rpm i hav to set it fully clockwise to about 3v any ideas please
Hi all ,
intrested to see any feed-back on this as mine does and is doin the same,but try to aim for 750-800 rpm vance :)
Hi all ,
thats not the way you set your base idle!,tps as you said should be set to approx 0.44-0.45v
even this shouldnt be used but is ok on the i.a.a unit at the back by the battery there is a screw that can be a ajusted to set required idle
pic of unit. screw is shown in green
hth greg
if you drop the base idle you can then correct the TPS output,also do a ecu diagnosis whilst your at it
clean some conections as well with electric cleaner TPS MAF etc
Thanks greg will have a look in the morning , will let you know how i get on Cheers `V`
you did unplug the tps after you set the voltage didnt you to clear the ecu of tps settings....mine rose until i disconnected the plug and put it back again then all was ok
yes i did that but it didnt make any difference . tommoro im going to adjust tickover and reset tps . And then see if the auto box will change from 1st to 2nd without a jolt . if any one else can shed some light on this i would be very greatfull . driving me mad now , thanks all
Check for air leaks.
Reset the TSP to the correct setting, and then adjust with the idle screw.
Do you have a stock intake? If so how clean are the filters?
You could try cleaning out your throttle bodies.
bad TPS reading will cause gear change problems on an auto give long delays before changing and as you say make it jolt forward
do the idle screw then TPS even reset ECU
