chassis number
Is there a chassis number stamped in the car if so where?
On the chassis ;)
Sorry :slap:
http://www.neuralmotion.com/forum/tech/year.htm
chassis no. is on the main bulkhead, the engine no. is a pig to find, the location is shown in the manual (rear of the engine) but in order to read it you'll need to clean off the dirt using WD40 and fine abrasive paper, the no. is stamped on a flat surface on the engine and in order to clean it you need to shove your hand between the engine and bulkhead while holding said abrasive paper and cleaning stamped surface
Should also be on V5 doc and MOT's
it is not registered yet was just checking if it was what it said it was, found the chassis number and it matches up with the data on courtesy nissan
cheers for that
jay
