July 12, 200521 yr err Ive just creamed my pants http://www.bulldogbroadband.com/residential/XPNP/about_8meg.asp unlimited transfers at just under £30 whats your views on this guys? is it :bow: or :xxx: ?
July 12, 200521 yr I've heard - Terrible Customer service and receive more complaints than any other broadband providor
July 12, 200521 yr Bulldog have a really bad reputation for customer service. So if you don't have a problem, you should be fine, but if you do, you could be on hold for a long, long time! :( I believe that to go with the Bulldog service you have to sign your phone line over to them too. That seems OK when you transfer away, but I'd be a bit concerned about what happens if you decide to leave and return to another ISP - it seems unlikely that you'd be able to just migrate in the normal way. And obviously you need an exchange where Bulldog have installed their equipment (check on http://www.samknows.com under Availability Checker and then LLU). If Easynet are also in your exchange, you may want to consider using their service instead, either using their ISP (http://www.ukonline.co.uk) or one of the resellers, e.g. http://www.f2s.com. Having said all that, my exchange is Bulldog enabled and not Easynet enabled and I'm pretty tempted by this myself! :cool:
