Coolant?
I've just changed a water pipe on the Z and topped the system with water for now to check all is ok. Whats the capacity of the cooling system? And what mix of coolant and water do you use? I was thinking 50/50.
Chris.
If you read the back of the antifreeze bottle it should tell you as a guide.......
at temperature about -20degrees (russia ect.) 50/50 is recommended.
over here -10degrees absolute lowest about 10% - 20% antifreeze will be OK.
Sorry dont know the capacity of the cooling system?.
