power streering
My mates 300zxtt has a problem, when hes driving and say approaching a roundabout his power streeing gets hard, he says he wiggles it abit then its fine again till it happens again any ideas? thanks.
enough fluid in?
Is it UK or jap?
Does it do it any other time?
He has just told me his belt for the air con broke and hes running without it, says the bearings in the pulley caused it to seize snapping the belt for the air con. :smash:
This wont affect the power steering though. I ran mine for ages without an aircon belt.
How about speed sensor going dicky? My power steering very occasionaly does this and the needle on my speedo drops suddenly at very low speeds. They're possibly linked
David
Hello mate,
I reckon it could be a faulty speed sensor.
The faster the car is going the tighter the steering gets, the slower it goes the looser it will get. Mine did the same J-spec import. Cleaned loads of plugs then it seemed to go away, couldnt tell you which plug though.
Hello mate,
Might have to give that a go. Do you clean the conector to the speed sensor, right under the car?
David
Got to be worth a try, might save you having to buy a new one.
mine does the same!!!!!!!! damp in connector for speed signal for power steering solenoid under stearing rack, connector to speed sender on gearbox. ok on a warm dry day lol
