June 21, 200520 yr to anyone whos fitted aftermarket front pads ie ebc etc did. what shims etc did you put back in with the pads ie just the metal plate supplied by ebc like I have or did you put the nissan grill in aswell. only my brakes are rubbing all the time on the front and Im trying to get to the bottom of it even took all apart and cleaned turned disc 180' still no difference EBC said the brake obviously makes noise when braking as the discs are grooved vented etc but you shouldnt hear anything when driving noise is from both sides cant believe BOTH my front callipers are knacked only other thing is I know my master cylinder needs a new piston might this be causing anything ie stopping the pressure from returning the callipers properly chris :)
chris :)
