NZR - tyre treads
Hi,
Just wanted to know what the minimum legal tyre tread depth is?
Vijay
1.6mm over 3/4 of the tread, 1mm for motor cycle,
i think
1.6mm over the CENTRAL 3/4's of the main tread pattern. the outer edges may be devoid of tread but must obviously have no cords exposed!!
Havnt you got to still have visible tread outside the central 3/4?
stick a 20p coin in the groove, if it stays its legal, if it dont its shagged!!
Seriously tho, I believe the LEGAL limit is 1.6 mm over 3/4 of the tyre.
But to pass an MOT test they have to be 2 mm or more.
The tread indicators on a tyre are at 2mm.
no, not any more - that was the regs about 10-15 years ago!
nope ;) 1.6mm!!!
Shows how long ago it was when I was an MOT tester!!! :eek: :eek:
1.6mm minimum depth on the central three quarters of the treaded width.
Visible tread on the rest.
That's what I thought - for cars anyway.
Pretty close to what the lads are saying.
YEEHAA!!
I was right then!!
Life in the old dog yet!!
direct from the testers manual:
Reason For Rejection:
the grooves of the tread pattern are not at least 1.6mm throughout a continuous band comprising
  • the central 3/4s of the breadth of tread, and
  • round the entire outer circumference of the tyre
Note: each side of the central band of the tyre can be devoid of tread (ie "bald") and still meet the pass standard
thankyou ;)
