Torque Wrench Settings
OK it's not a Zed, but I'm just replacing the exhaust manifold gasket on my Rover 820 and Haynes suggest a 45nm setting for the nuts and bolts to do it up.
Does this sound right to anyone? That's barely on!
Cheers,
Matt.
if that what it says.
I did a wheel bearing on a corsa and that said the hub nut was to be on 225ft/lb or something.
Presumably it has a squishy gasket underneath. Better than shearing off the studs anyway !
OK, cheers for that. I suppose I don't want to squeeze the life out of the gasket, so it makes sense really.
Ta muchly.
