Right, got my Zed import, with no manual for the interior stuff.
So, how does it all work ?
I assume by pressing AUTO its the air con or climate con, and you set to the temo you want.
What does recon and economy do. i assume recon stops external air entering. what is the econ button ??
Also, how do i just get hot air to blow ???
cheers
Dai
http://www.300zx-twinturbo.com/cgi-bin/manual.cgi?list=ha&dir=&config=&refresh=&direction=forward&scale=0&cycle=off&slide=96&design=default&total=168
Try clicking on that Dude. Didnt think my aircon was working til I read this and worked out how to use it!
Basically ....
AUTO brings the aircon compressor into play ie. cold air in summer
ECON is climate control with out the compressor ie. warm air in winter, just uses air from outside.
REC circulates the air in the cabin. No outside air enters.
Set the temp you want and the temp will'll soon settle down.
When its cold and I'm on the move I press OFF, then set the temp ie 20C the press the direction buttons so the air's going where I want it. I find that really warms up the cabin without blasting air everywhere!
When its hot, press AUTO, temp to 10C. Temp will drop rapidly, after a bit, set the temp to 15C, rather comfortable!
Well thats my opinion!
Andrew :)
cheers butty !!! thats what i thought.
where are the direction controls? ? ? am i being stupid, or is it just the button for the screen?
also, what does the "mist" button on the wipers do ???
If yours is like mine then it doesn't have direction control, there are two types. The mist button just means it wipes once.
Just seen yours in an import. I dont have the 'mist' button. Just be daring, press it and see!
Direction button...Yours might be different but it looks like someone sitting down with 2 arrows and a demister sign. HTH
dont think i have this button you speak of !!!
seems to be just screen or everywhere!!
The series 2 heater controls have the direction adjustment and the earlier series 1 heater controls dont. It is meant to be controlled automatically.
  • 4 months later...
Is it possible to swap series 2 controls onto a series 1 car so I can control the direction of the air? If poss is it a straight swap and where can I obtain a set?
Thanks.
