driving without oil cooler....
how bad is to drive without a oil cooler for the gear box....i've changed the standard water rad with a KOYO one and now i don't have a rad for the gear box. can i drive the z without a cooler for few days till a buy one?
:dance:
would not recommend it. even the std cooling thru the rad for a gearbox is a bad idea.
of course not ...but i was thinking cos i realy need the car to go to work ..is about 10 miles each way... is this such a long distance for the oil to get so hot?
:dance:
Take a few sickies :hurl: :hurl: untill cooler is fitted. ;)
Yup, damn good reason for a few sickies if you ask me
:))) yes that's not a bat ideea but thing is i need money to do other bits as well...how much is a gear box any way? :slap:
:dance:
An oil cooler will cost you just over a oner, maybe a bit less, and a few hours to fit if you take your time.
A new box will set you back about a grand for a good recon.
I know where the smart money is.
My first zed had no aftermarket oil cooler, lasted just under 6 weeks and it cooked the gearbox, i bet i didnt even do 500 miles in it.
mine just cost me £1700 for a recon but did have it upgraded and they had it 5 weeks!!!!!!!
I have just removed an front mounted oil cooler for my old Autobox, it comes with pipes and is in VGC.
£50 including postage if your interested....
The standard autobox oil cooler is so feeble I doubt whether it would make any difference ! cretianly not over short journeys. In fact I did wonder whether the oil flowing through the main rad, as it does, was done in order to heat it up faster ....
