probs with my car
as some know ill be doing the ecu check later but reading some previous posts.
I cant understand ?
if it is det then it only runs certain boost ie 6.5
well my cars boost goes right round to just before the 7 mark which according to some prev threads is almost 14 psi :eek:
BUT it still only gets to 60 in about 8-9 seconds so could it not be the det???
but another thing is i know its not supposed to be accurate but there is no way my car is running almost a bar of boostI think I would have felt it
Im going doolally!!
chris :D
how do I figure out the flashes on the ecu check??
it says long flash short flash then it gives you a load of numbers?
BRING BACK METRO TURBOS WITH CARBURETTORS ALL IS FORGIVEN
A long flash is 10, a short flash is 1. So 5 long followed by 5 short is a code 55.....everything ok.
As for the boost, my jap boosts to just before the 7 too....dont know what psi that is....
thanks mate its supposed to be 14 psi
there is no way my car runs 14 psi, even when it wasnt so slow a week back
it cant be 14 psi if your not running boost jets or a boost controller, stock is 9psi (i think, but somone will confirm)
as far as I know the only mod is a blitz filter, but thats what I mean
why does it go up to +7 and I presume other peoples do aswell if thats 14 psi,...
Id know if it was modded I hope it was quick but not that quick
and also the 0-60 is way to long
Im confused
but the check will tell me I hope
if only there was more hours in the day
chris ;)
+7 what? without any units its meaningless. if you were running 14psi the needle would top out the stock guage
thats what Im saying
I have the jap gauge which is measured some potty way, the needle doesnt quite touch the +7 mark but even still thats saying to me to me at least 12-13 psi
and If I had a faulty det sensor surely although its not the most accurate the gauge would only go to around the +3 mark = about 6 psi in safety mode
chris :duffer:
ok i get you, well if there is no misfire and the engine isnt getting bogged down i guess either ur guage is way out or theres a problem with your tranmission. clutch slipping? autobox on its last legs?
Yeh I've got a Jap import too and the stock gauge measures in millimeters of mercury (mm/hg) x 100.
Mine has no boost upgrades but at full chat measures about 6.5 on the gauge x 100 gives 650 millimeters of mercury which = 12.56 psi (theoretically).
The trouble is I cant see how a tiny gauge like that can really give an accurate reading at all, apart from a rough indication i.e no boost - half boost - full boost.
Beyond that get an aftermarket gauge if you want to rely on it a bit more, but without a calibrated gauge with a mirror reading, capable of adjustment for altitude, temp and barometric pressure at time of reading it's never gonna be 100% accurate - we are talking about a difference of 3.5psi, shifting your head side to side can prob adjust your indicated reading on a stock gauge by + or - 1 psi alone ;) HTH
it has a brand bew auto box
could still be a problem but I doubt it? :bow:
