Gearbox Rear Oil Seal
Can you replace the rear oil seal with the gearbox still in and do you need any special tools to remove the seal.This could be next weeks job
Job can be done with box in place, although seal extractors are the best way, careful use of two slim screw drivers sholud lever it out ok, exhaust front sections will need to come down to get clear access.
hope that helps
Jeff TT
WEZ just make sure if you split the propshaft in the middle you mark the prop on either side as they are both balanced otherwise it will be out of balance
Ryan
thanks for that Jeff and Ryan ,looks like I will be under the car again and in the dog house as well :rolleyes:
What the best oil to put back in and how much
