warning light
well this one's got me baffled (well it dont take much) ?
When i start the car a warning light comes on ?, on the left hand bottom bank of warning lights (next to the hicas warning light). it says LIGHTS, i have checked my lights including indicators and brake lights and they are all working.
This started to happen when i reconnected the battery ?, when connecting the battery i got a larger than normal spark ?, have also checked all the fuses and cant find a blown one? WOTS GOING ON ????? HELP....... :smash:
Is this not the night time warning light incase you forget.:rofl::rofl::rofl:
Seriously, I am sure I read some where that it was to do with the ABS System although this sounds just as daft. Maybe some one else could shed more light on the subject
Fitzy:duffer:
i could understand it beign so if i removed the keys with the lights on, but it only comes on when the engine is running ????
44 views and still no help ???, someone must know, have also noticed that the original boost guage is not working, but my new one is, and it T's off the same boost pipe?
Thats wot i dont understand, i have checked every fuse that i can find, even the lot near the go fast peddal (in my case not very fast) ? Has anyone got a hand book to see what the light means.
The only thing I have heard this with is when you do a inner brake light conversion for fogs ... something to do with a relay needed ... soz mate
as chrisp said poss something to do with a light converson. i dorve wheelmans (Marcus) car down to japfest and thought that there was a light out when i put on the brakes, but he told me that it was because of the fog light con.
NO i removed it...and only put it on for the MOT....its extra weight saveing??
Well after a day of checking everything i can possibly point my multi meter at, i still cant find whats causing the warning on the dash to stay on, the only thing left is a unit in the boot next to the offside light cluster, i think its the stop and tail light sensor,but when i look at the wiring diagram it only shows 1 sensing wire comming from it, but mine has about 8 or so, if i unplug it none of the rear light work and the light on the dash still stays on?
And have noticed tonight that the battery light on the dash is glowing but not bright its very dull (just like me).???? Help.
I still cant find the fuse or relay that controls the standard boost guage cos that still aint working. So is there a fuse just for this????
Its still running in saftey boost mode, and the ECU say's all is clear, so wot the fook is going on? :wack:
Also today i have replaced all the Injector connectors (they were well green with corrosion), and now the car is ticking over at 1100 rpm, but runs very smooth and sweet, but no fooking boost, only 6/7psi (on my extra boost guage).
so come on guys the jokes over, i have sufferd today, i have hands that would look better if i stuck them in a meat mincer. Help
