Brake master cylinder
Please remind me if this is a known problem on the ZX......
......every so often I have a pool of brake fluid in my garage under the car, right below the master cylinder.
I top up the fluid and it is fine for weeks, no leak at all, then suddenly the pool re-appears and the level is down a couple of cms :confused:
I asked my mechanic to look at it 2 weeks ago and he found nothing wrong. Typical. He topped it and told me to call him if it leaks again. It didn't.......
........until this morning :headvswal
Richard :x:
Could be the master cylinder itself leaking, have a look directly underneath the cylinder on the bulkhead and see if it is that, maybe double check your clutch fluid levels as well, the slave cylinder is directly underneath the master and one of the usual suspects as well!
