protoj · 3 hours ago 3 hr
Hey folks,
Ive just deleted all the pics from my profile in my rides section and updated them with new ones i took this weekend. This time i should b collecting my car this week 4 real. As u can see the exaust, spoiler and front indicatators need 2 go on.
Tell me wot u think!................
K4$H
