power for sub amp
where would be the best place to take power for a sub amp from, straight from the battery ? if so, where is the best place to feed the cable through the bulkhead.
cheers
paul
yeah off battery, fed mine through the side - big hole and theres loads of vacuum hoses going down there - pops out in the front nearside wing. from there just took off sill protectors and fed through carpet.
just make sure the rca cables run a different route so as not to get too much interference - ran mine through centre console and under carpet.
hope this helps bud!
as you look at battery itll be on the right hand side level with the bottom of the battery - going into the front wing.
i made a little slice in the rubber hose that carries all the electrics for the front door - then you can poke the cable through the hole that leads into the passenger footwell.
