More O2 sensor woes
Does anyone know if you can buy the boss that the O2 sensors screw into? Had to resort to mild violence to get out the old sensor and from what I can see I may have damaged it. :smash: Also, what size is the boss? as I will need to invest in the right size socket to remove it.
Mike Feeny (MJP in the traders section sells them) they're cheap.
Think it's 32mm from memory
Cheers John, I'll drop Mike a line
Gareth
