- Adjust your preference.
- Select Site settings.
Safari (iOS 16.4+)
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
Firefox (Android)
- Tap Notifications.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
Hi
I have just bought a very nice 1990 Twin Turbo (import) and need some advise.......
I want to service the car are there any dramas i should consider when..
1/ Changing the plugs
2/ Oil and filter
3/ Fitting an induction kit
I also want to increase the boost am i right in saying i need to upgrade the chip inside the ecu and then add a boost jet? what is the boost jet and where does it go?
What sort of psi should i look to run and what sort of increase should i expect to see, can anyone recomend a good suppler for the service parts and upgrade kit, what sort of cost should i expect to pay for the induction kit?
I found the engine sound under boost to be a bit tame (although f**** quick) will the induction kit give it a bit more of a noise?
Is fitting a boost gauge hard?
Can a good quality bleed valve be used to increase the boost and if so where is it fitted?
Thanks and sorry for all the questions!!! :hyper:
