Few questions on plenum bypass??
Can I use silicone hose to do the plenum bypass? if not whats the hose to use and where would be the best place to get it from.
I have read up on the on plenum bypass from a link given in the advanced tuning forum, there is a bit on there about a hose that goes from the carbon canister to the balence bar being as I have removed the carbon canister do I blank the balence bar or reroute the hose else where :confused:
cheers
if you are talking about the plenum water pipes bypass you should use a good quality rubber hose which will take the pressure in the water system, done a few of them now and never touched the carbon cannister????
carbon canister removal guide tells you to blank the lines so I guess that's what you do (balance bar + throttle body)
Silocone hose will take water temp and pressure no problem,Its what Samco make a top hose from;)
shame the samco hoses they sell for the intercooler pipes are shite,but i presume thats what you mean LOL ;)
