Please Help Hesitation and power loss problem
:headvswal Hi I have a late 91 TT I had a very slight misfire and hesitation witch got worse over time. After lots of money taking it to be checked out by specialists and changing the fuel pump, fuel pressure dampener, fuel pressure regulator , fuel filter i tested it with different coil packs, with no change the car suddenly started running on 5 cylinders (this happened over 4 months) then tested the injectors and found one was not working. Got a new one and after hours of fun taking off the Plenum and re fitting it the car ran fantastically for 3 weeks, then the slight misfire and very bad hesitation on acceleration came back. Cam belt has been changed new plugs cleaned the throttle bodies; I still have the same problem. I cannot believe another injector could have gone. the car is also running very rich on one bank, rev's are 1000 and cannot be ajusted, the computer has been reset and all diag codes are ok.
Can anyone help please
Welcome,
I think your best bet would be to take to one of the Recomended Zed specialists such as Ztech. See Traders forum section for their details.
Have you had the PTU checked ?
What "specialists" have you been using ?
Hi have spent enough money at specialists thanks, yes tried a different one and it has been tested.
Welcome,
Have you been to Z tech?
I dont think so .... Ryan is a top bloke ... he will sort it out ...
Where is Z-Tech
Look on the Traders Forum ... near Swindon ... Ohh by the way that is 10% COMMISSION TO ME ... :-)
Zed World and Nistech
QUOTE=Legrath]Welcome,
Thanks anything is worth a try i need my power and performance back i cannot enjoy it at the mo.
J14 M4, between Newbury and Swindon. http://www.ztech.co.uk His customers come as far as Scotland just to use him.
Who have you been using previously ?
have u checked ur injector connectors and ur coil pack connectors mate?
