Lost all my power no ignition lights nothing?????
I have had my engine bay sprayed and since its come back there is no power at all the alarm still works but there is no ignition lights no stereo, indecators, lights and so on any ideas where the main fuse will be for this? I have checked the fuse box near the brake servo but they all seem ok :confused:
Check the hidden fuse box by the accelerator pedal mate ... You will see it.
when my ignition fuse went the fuse looked fine, i swapped over the abs one to the ignition one and it was fine so the spotted the problem.
Everything is working apart from electric windows, ignition lights and indecators? have put a meter on all the fuses all ok have checked all the fuses in the footwell they all look ok although I dont know what does what as its all in jap!
Everything is working apart from electric windows' date=' ignition lights and indecators? have put a meter on all the fuses all ok have checked all the fuses in the footwell they all look ok although I dont know what does what as its all in jap![/quote']
Just for you http://www.300zx.co.uk/tech/fuse-translation.htm
