towing a Zed
Is it ok to tow a Zed with all 4 wheels on the ground, ie on an A frame attached to the chasis?
or will it damage anythin ie diff, HICAS?
cheers
Dai
is it an auto? as if it is then i have heard that you must not tow over 30mph and for longer than 30mins
not sure about the rest
True with all cars :)
If its an auto, you should always disconnect the prop, or you'll damage the gearbox.
Its a manual. Guess towing is out then if 30mph and 30mins is max.
cheers
dai
You should be ok towing a manual, its to do with the lubrication of the gearbox, an auto wont get lubricated if its being towed, a manual shouldnt cause any trouble.
