Would this wheel fit?
I've sourced a nice set of 19" alloys: 8.5" front, 9.5" rear. I know the correct offset for the Z32 is +30 front and +35 rear, however these are +35 all round. Bearing in mind I have a camber correction kit ready to put on, that they would need to clear the GTR Calipers and that I will probably have to use spacers anyway, front and back, due to the wide arches going on, my question is: will they cause any problems? Sorry for my ignorance in this area :o
Leigh.
They will fit if the tyre profile isn't too large. If the profile of the front tyre is too large then it may hit the knuckle arms (the bit which is connected to the upper control arm) as it curves in the towards the wheel at the top.
Whether the wheels clear the calipers is another question and that will depend on the design of the wheels. Some wheel manufactures have high "H" and low "L" disk. The high disk wheels have a greater caliper clearance yet retain the same offset as the low disk wheels.
