VTC solenoids
I could do with a bit of advice guys.
I'm not fully up on these, although I understand what they do, does anyone know what the result would be if they didn't work properly, are we looking at a huge loss of power? I think Duffy told me they only operate at higher revs, so does this mean you would loose top end power.
I don't think the ECU detects them, so how could you check they are working properly.
Any info much appreciated.
You can use conZult to operate them. The engine note should change if you do it on idle. You also might be able to hear each one work it you listen as you turn them on/off. Or disconnect one at a time then do the test and listen for the change.
Dave when you pop down next if you havent managed to test them then I can run the consult for you.
Cheers Dave, didn't know you had a consult, thats worth knowing ;)
