April 12, 200521 yr can any 1 help my zed32 has no lights,wen i turn the head light and side light switch i get main beam only my fogs dont work from the switch yet my rear heated screen works and the cruise control works can any 1 help :headvswal
April 12, 200521 yr Look in the fuse box by the GO GO pedal .. I think it is the third one in from the top, could be the second. I had the same problem. Fuse has blown. Check if anything is shorting it out.
April 14, 200521 yr :hyper: :rofl: thanks m8 that was the problem not got much space down there either specially wen pissing it down and hav ton keep door closed cheers again :hyper: :rofl: Look in the fuse box by the GO GO pedal .. I think it is the third one in from the top, could be the second. I had the same problem. Fuse has blown. Check if anything is shorting it out.
