reset ecu
dnt no how to do it on th ecu but u can disconnect th battery, step on th break peddle and leav it for half n hour
I think the ecu clears the old fault code after 50 starts as long as it doesnt come back again.
its easier than that,
when you short out the ign/chk pins on the consult plug and check the codes, short out the ign/chk for 2 secs again and the engine check light will stop flashing and stay on.
i found leaving the battery over night wasnt enough to clear the codes.
wat two pins are these?
sorry, the consult plug down beside the bonnet release, if you bend a paper clip and short out two of the pins for 2 secs with the ignition on, then the check light blinks the code,
there was a link but i cant find it.... any one?
