November 28, 200025 yr I've decided to put on driving lamps as per Nico's ride pic. Whats the best place to gain access to the cabin for the wiring ? I'll shut up now ... Glenn
November 30, 200025 yr There is a hole in the firewall, just on the drivers side half of the engine that i think there is a heater pipe and wiring going thru, Check out Bobs AVC-r Install iln Bobs place as he explains how to get wiring thru the Firewall in that. Good luck im sure you will be happy with the effect. Z ya Nico91TT
November 30, 200025 yr I would run the wires through the same hole that the bonnet release cable. Are you going to fit a relay inside the car or in the engine compartment? You might find a space in the stock relay box in the engine bay! Steve
Glenn
