Fuel Tank Vacuum
Is There Some Sort Of Vacuum Pressure Release Valve For The Fuel Tank?
Went To Fill Up Today And The Fuel Cap Was Being Sucked On Harder Than Linda Lovelace!
Drove Home About 3 Miles And Vacuum Was Back Again. Must Be Giving The Fuel Pump A Hard Time.
dont believe there is a breater on this system, as there is a pressure releif system in the cap.
Mine did this too.....
If it is a problem you could always drill a small hole in the tank to relieve the pressure.....NNNNNNOOOOOOO...... :x:
fuel tank vacuum is normal, unless its really extreme its not a problem.
Strange coz mine is always being pressured to blow off :eek: rather than sucked on :x:
:rolleyes: :rolleyes: Not what it sounds like :rolleyes: :rolleyes:
Mine always has pressure behind it not vaccum, the question was asked on here and we were told pressurising is normal , its a easy way to tell whether you have a leak or not . :confused: :confused: :confused:
Now i am confused. :headvswal
colin must have got confused in the excitment ? and dont no if she was blowing or sucking :-)
The fuel tanks normaly have pressure rather than vacuum, the fumes are recirculated through the carbon canister behind the near side front bumper, this is vacuum operated from the plenum, possibly a fauly there somewhere causing the problem.
Jeff TT
linda lovelace :cool: :cool: i bet 90% of this forum does nt even know who this chick was,i do with fond memorys :xxx: :xxx:
she did it for me mate!
