motor oils..
Hi to all. I've noticed that everyone has done the engine oil thing to death, so apologies about this thread. What i have been wondering , what is the best engine oil, gearbox oil and diff oil to put in my beloved z32 uk tt.. :bow:
thanks
Mark
thanks
Mark
oh god here it goes again !!!!! :headvswal
What ever I say, someone will disagree. What ever they say, someone else will disagree. And I dont know the answer anyway.... So I am saying almost nothing, and no one can disagree with it. So what am I going to say?
DO A SEARCH.......:-)
didnt want to open a can of worms, will look elsewhere!! lol
ROFL... :rofl:
Personally I have chosen an oil that is recommended by an engine re-builder who knows his stuff as they get to see "the proof in the pudding" if you know what i mean.
Millers 10W60...for a twin turbo jobbie..will be different rating for a N/A
hehehe...this should get em started again :x:
yeah, Millers have been recommended to me by mr F at mjp, an expert on all the Z's, he's found this to be the most used by enthusiasts.
I am at the moment changing my diff oil as it is off the car for cleaning, so recomendations would be appreciated. ( no mention of engine oli ! )
It's gotta be Miller's every time. Use fully synthetic if your Z is low millage, if it's done more than 100,000 then Miller's semi-synthetic is a good bet.. 10-40w to 10-60w... Miller's also do some sepcific gearbox oil too...
Yep pretty much done to death - especially when I appear.
So, what should you be using was your question, here's the answer. To find out what I recommend you'll need to pm or email me as it will probably cause another oil war.
Nissan, 300 ZX, 300 ZX Turbo (Z31), 1984-1990
Manufacturer: Nissan Motors Co., Ltd., Tokyo, Japan
Drive type: r.w.d.
Cilinder capacity: 2960 cc
Power output: 230 HP/169 kW at 5200 Rpm
Engine VG30ET
Petrol, 4-stroke, 6 cilinder, V, 4 valves/cil., Turbo, liquid cooled
Capacity: 4 liter
Filter capacity: 0.4 liter
Use: Normal
Change 5000 km/6 months
OEM recommendation
Above -20 API: SF SAE 15W-50
Above -20 API: SF SAE 10W-30
Above -20 API: SF SAE 10W-40
Above -20 API: SF SAE 10W-50
Below 15 API: SF SAE 5W-30
SAE 5W-30 oils are recommended for use in extremely cold weather conditions only.
Under severe operating conditions: change more frequently.
Capacity including oil filter and oil cooler.
Differential, rear, (4x2)
Capacity: 1.8 liter
Use: Normal
Check 10000 km/6 months
OEM recommendation
Below 40 API: GL-5 SAE 80W-90
Below 40 API: GL-5 SAE 75W-90
Below 30 API: GL-5 SAE 80W
Below 10 API: GL-5 SAE 75W
From -10 to 30 API: GL-5 SAE 85W
From 0 to 40 API: GL-5 SAE 90
Above 10 API: GL-5 SAE 140
Transaxle, manual
Manual
Capacity: 1.9 liter
Gears forward: 5
Gears reverse: 1
Use: Normal
OEM recommendation
year-round API: GL-4 SAE 80W-90
Transmission, automatic
Automatic
Capacity: 7 liter
Gears forward: 4
Gears reverse: 1
Use: Normal
OEM recommendation
year-round Dexron IIE -
Power steering
Capacity: 0.9 liter
Use: Normal
OEM recommendation
Hydraulic brakes system
Use: Normal
Change 40000 km/24 months
OEM recommendation
year-round Brake fluid, DOT 3 -
Hydraulic clutch system
Use: Normal
OEM recommendation
Cooling system
Capacity: 11 liter
Use: Normal
OEM recommendation
year-round Water with antifreeze (ethylene glycol base) -
Nissan, 300 ZX, 300 ZX Twin Turbo (Z32), 1990-1991
Drive type: r.w.d.
Power output: 282 HP/208 kW at 6400 Rpm
Engine VG30DETT
Capacity: 3.4 liter
Use: Normal
Change 10000 km/6 months
OEM recommendation
Above -20 API: SG SAE 10W-30
Above -20 API: SG SAE 10W-40
Above -20 API: SG SAE 10W-50
Above -20 API: SG SAE 15W-40
Above -20 API: SG SAE 15W-50
Below 15 API: SG SAE 5W-30
From -20 to 15 API: SG SAE 10W
Below -10 API: SG SAE 5W-20
Above -20 CCMC G4 SAE 10W-30
Above -20 CCMC G4 SAE 10W-40
Above -20 CCMC G4 SAE 10W-50
Above -20 CCMC G4 SAE 15W-40
Above -20 CCMC G4 SAE 15W-50
Below 15 CCMC G4 SAE 5W-30
From -20 to 15 CCMC G4 SAE 10W
Below -10 CCMC G4 SAE 5W-20
SAE 5W-20 is not recommended for sustainded high speed driving.
Under severe operating conditions: change every 5000 km or 3 months.
Capacity: 2.1 liter
Use: Normal
Check 40000 km/24 months
OEM recommendation
Automatic
Capacity: 8.7 liter
Gears forward: 4
Gears reverse: 1
Use: Normal
Check 20000 km/12 months
OEM recommendation
Transmission, manual
Manual
Capacity: 3.1 liter
Gears forward: 5
Gears reverse: 1
Use: Normal
OEM recommendation
year-round API: GL-4 SAE 75W-90
Power steering
Capacity: 1.3 liter
Use: Normal
OEM recommendation
Capacity of models with HICAS: 2 l. Top up only.
Hydraulic brakes/clutch system
Use: Normal
OEM recommendation
Grease points/nipples
Use: Normal
OEM recommendation
year-round Lithium base multipurpose grease NLGI No. 2
Cooling system
Capacity: 10 liter
Use: Normal
OEM recommendation
Hope this helps.
Simon
thanks oilman, tried to send you a pm but you couldnt receive one. I need to change the diff oil now, what would be your recomendations?..would it be ok to get back to you when i need to do the engine and gearbox. ( i'm restoring the car !)
regards
Mark
I would recommend a 75w-90 that has GL4/GL5 and approved for LSD's or a dedicated 90 LS oil.
Try emailing me through my profile, it appears my PM capability has been disabled. If you have problems then contact me through SXOC.
Simon
I disagree........... :hyper: :mac1: :nelson:
:rofl: Oilman, heard a rumour you live / work near a Fish & Chip shop is this true??? If so you're just down the road from me!! :rofl:
Nope, I work at HQ on the Cardrew Ind Est.
I also happen to own the little trade forecourt next to Morrishs'
Simon
Ahh, that will be the Fish & Chip shop then just down the road from my house!!! The boy's at Richard's Bros recommended me to the Miller's Stuff - seem's to work a treat!!! Good to know someone on here is near by for advice!! Me Red Zed's normally parked outside Comet in Pool there... Cheers Simon!
They used to supply only Silkolene years ago. I think they still do but probably too expensive for most of the GTI and SRI boys!
Simon
Forgot to say, the guy at the chipshop used to have a 300ZX about 12 years ago, think he's got a Jag now though.
Simon
Yeah, I've know Nigel for quiet a few years now!! I was still at school when he got his ZX - always promised myself I would have a car like that one day, finally did 3 years ago when I hit 25!! He still sayz the 300ZX is probably one of the best cars he's ever had!!
