Power light flashes on startup - tt auto
Lately I have noticed the 'power' light flashing a number of times on startup. Anyone know why this is? Thanks.
self check I believe, as long as it goes out nothing to worry about
the error i have is 14-speed sensor....which i know....but i don't know if is got anything to do with this.
yes it is, the power light flashing is telling you to that there is a stored ECU error you need to look at. in your case its the speed sensor
How do I check it, and is their a list of codes.
Is this error code related to my previous problem of delimiter/non working speedo/no power steering. :headvswal
more than likely yes, generally the power light flashing is an iffy/knackered
delimiter, i would deffo remove it and see if it cures all your problems in one go
Delimiter - what lol? :confused: It is telling you theres a stored error code :) Try shutting off and firing up again, sometimes helps with a bad connection on eg a TPS until you can get it sorted.
If the light is *flashing* that is ;)
