Whos lowered there Z and
had any problems ................ seen some on ebay [from states] but rather spend my hard earned ca$h with one of are traders.
Running 18" rims would/has this caused any probs
Dave
19" lowered. ove the arches mate no probs at all only front inside tyre wear slightly
:D Running same as you bud.....:rofl: as you know :cool: and mine is lowered 35mm, no probs at all fella :cool:
;) Could yours go lower.say 40mm?
You can mate but will be very close ........if you hit thoses dips on the rd / motorway you will ground out :( as i do sometimes if they are deep....:(
mines a bit to low , can't do speed humps, and grounds out on uneven surfaces under heavy braking
mine is to low and to hard split my front cross member on a pot hole doh!!!handles like a dream though ,grinds out on anything thats not flat SPEEDBUMPS are just inconsiderate fu#**~#+@$terds
Ditto with me. Totally impractical (multi-storey car-parks are a dim and distant memory and there are some roads in my area that I just can't go down due to speed bumps ;)) but the handling, for a car of its nature, is with no exaggeration superb. As the saying goes, there's no such thing as a free lunch :)
Leigh.
I'm on 18" with 35mm lowered springs, and I wouldnt advise it and i have the OE front spoiler, your probably lower.
A while back I had to put the original wheels back on the front and ended up ripping the exhaust off on a speed hump, followed by all the engine under tray on a cattle grid, granted that was a further inch lower, but you need a little room for rocks in the road etc.
I,d love to do the american thing and drop the roof down an inch instead, that would look the danglies. :cool:
Cheers guys thanks for the feed back ;)
Dave
russ, yours would ground out driving over a matchstick!! ;)
Eibach springs drop the car 0.8", which is a sensible amount IMO
My zed was lowered when I bought it, clearance is about 4/5 inches, would not go any lower than that, have trouble with speed bumps, front end twatting off kerbs when parking, cant get it on ramps in garages, even have trouble getting it on and off me drive, but on the plus side it hadles absolutely class. If I had a choice I would lower it but probably only by about 30 to 40mm.
