gauges
what wires in the lights binacle can i tap my gauges in to? right i know how to pipe in the boost gauge an water temp gauge but how do i pipe in oil pressure gauge? have got 1 of them sandwich thingys fitted from chris getgreddy. what pipinghas to be used as the 1 supplied will prob melt? cheers :confused:
i ran a wire to the light in the autobox, as it the only one i could easily find with a black and red wire
wire them into the ignition switch or the light binnacle remove pod cluster find a switched live job done,or use ciggy lighter or glovebox light.
ground use anything with a clean contact
as for the oil pressure not sure,someone will help ;)
