I have got a rather strange problem with the temperature gauge.
It is the std gauge in the dash...
When ever you rev the car (say from 2,000-4,000rpm) the temperature gauge drops to almost the cold mark.
I do a 50mile journey and it was still doing it at the end.
The engine is normal temperature.
Any one got a Didgeredo please?
:rolleyes:
Temp sensor!!
located on the front of the engine, on the water pipe (hard type) 2 connectors its the right one, should be yellow.
Check the connection, see if it has green fir on it and also check the clip.
There not expensive and there is a few traders on here that can get them, MJP would more than likely have them in stock.
Rich
:rolleyes:
LOL - my aftermarket water temp gauge goes up with engine load/revs. When the engine is hot, it stays where it should, but until then, the temp reading drops when idling :rolleyes: I've tightened up the sender and this seemed to help, but it still happens now and then :(
Sorry to hijack! :slap:
Steve :)
'93 UK TT Manual
Temp sensor!!
Rich
;) CheerZ ChUnK :cool:
At the lakeside meet i do remember it suddenly zipped up to max on the gauge yet the car was normal temperature...thought nothing of it till this morning when it played up again.
Is this a common problem then :smash:
and cybernet...Feel free to whore as much as you like ;) :slap: :tongue:
Temp sensor!!
Rich
Its actually the black connector which feeds the dashmounted temp guage - the yellow one is for the ECU only.
Make sure the black connector makes good contact (clean both male & female connectors if necessary). I've had to tie-wrap mine to the connector to keep the airflow from the fan from pushing it off the connector ...
Dan
Ok :tongue:
'93 UK TT Manual
Temp sensor!!
Rich
I got this looking from the front of the engine....
Yellow on left and black/brown on right. :smash:
I take it its the smaller one on the right?
Dan
Ta very much :cool:
:confused: Now where did i put my cable ties? :confused:
and cybernet:-
and cybernet...Feel free to whore as much as you like :tongue:
Ok :tongue:
:rofl:
It will be the right Black / Brown one bud :D as i had JD solder mine ....gauge was all over the place....:cool: OK now..;)
:nana2: NOW THATS AN IDEA :nana2:
tA
We live and learn bud :D thats the fun of this place :cool:
