please can anyone help me finding the right grade of bearing
for my 1990 tt auto uk spec
ok then here are the numbers as i see them,
reading the block from the oil pump end the numbers read
2 2 1 1
and on the crankshaft at the oil pump end they read
F2 1 2 1
i think but not 100% that the grades required would be
4 3 3 2
right then now for the conrods
on the crankshaft at the flywheel end the numbers read
1 0 1 1 1 11 (11 must mean a 2 please can you confirm)
and on each of the conrods they read
no1 1G1
no2 1G0
no3 1G0
no4 1G1
no5 1G0
no6 1G1
so im not sure what grades are required for these, if someone can help me figure it out please that would be ace!!
also im replacing a piston for a second hand one, its in good nick but i need to fit it with my conrod is it ok to do this, i will double check all the dimensions of the piston pin and check for play
thanks in advance
dewi.
>> 4 3 3 2
correct
no, you must have misread...only conrod grade nr. can be a value between 0 and 2
I suppose you have seen this diagram ?
2 2 1 1
F2 1 2 1
4 3 3 2
no1 1G1
no2 1G0
no3 1G0
no4 1G1
no5 1G0
no6 1G1
thanks in advance
dewi.
dewi
the 11 symbol which will be either higher or lower than the rest of the marked line on the crank does indeed mean a 2 so your rod bearings will be as follows
201213
Ryan
