Interior lighting....again!
Help me again, I recently asked for advice re fuses for the interior lights and the stereo going off. I have now located every possible fuse to the lights and stereo and checked them all and found they were fine! Does anyone else have any suggestions. Basically I was replacing the interior bulb, it lit up for a fraction of a second and then nothing worked again.
Fuses may be okay, but are you getting any voltage to them? Best way to track down the fault is either working from the bulb or the battery. From the battery, as soon as you get to a place where the voltage has gone, you now know the loss is between there and the previous place you checked. May be a broken wire! Alternatively working back from the bulb, as soon as you find 12v you know the break is just after that. Check the supply voltage on the fuses or relays that you can reach as a starting point.
Have to say though it really does seem to be a fuse. Are you sure your getting a voltage on both sides?
Simon.
