wheel bearing
gonna have a go at changing this tonight, anyone done a rear bearing before, any tips
Cheers Chris
Just finished both of today, I got the hubs with the bearing in from Andy
o/s was Tw+t of a job n/s easy
Tools :-19mm ,17mm,12mm & 10mm ring spanner same with the sockets , you may(will) need a slide hammer or a hub puller I had both
Best advice is watch out for the brake disc cover it is made my Gillette forking sharp :cry:
just gonna take the hub unit out , got a press at work i can use to push the bearing out
