how do you get to the side light bulbs and driveing light bulbs :smash: :headvswal
Its a bit fiddily but you just about do it.... :nelson:
If you can't fit ur fingers in their then get your wife or girlfriend to do em...just make sure you dont touch the glass on the bulb :shock:
GOOD LUCK
i know how to get the fogs out but never changed the bulb so ul have to go from there:
1. unscrew two screws on indicator and remove the unit
2. three 10mm nuts hold the fogs onto a fibreglass support, easy access through the hole you just opened
to get to the headlight bulb you need to unscrew plastic cover and remove the connector and rubber sleeve. thers a wire clip that holds the bulb in that you have to push down and out (i think).
