Urgent - O2 Sensors
Hi
Am just changing the sensors - 2 brand new ones.
Same cable length. Does it matter which way round they go.
Are they sided or not?
Mark
Hi
Mark
They're not sided. The only difference "should" be the lenght of the wire. One connects at the top of the back of the engine block, the other at the side of the engine block (driver's side) and will require a longer lead.
Dan
Dan
Hi Danny
Thats what I thought - but they are both brand new from nissan and different part nos.The only difference I can see is they have different
Bosche part nos on the sensor - but that doesn`t help.Cables are exactly the same length!
Mark
IIRC, the difference was only the locator clips on the cables.
Vijay
Vijay
True (forgot about that) ...
I have two sensors I ordered ages ago and just had a look. Yes, the locator clips are different; no, the part numbers are the same; and yes, one wire is longer than the other by about 10cm ...
V. confusing but you should be ok with what you've got.
Regards,
Danny
