February 23, 200520 yr Right...Im getting ECU Error Code34 - Det Sensor circuit (Det sensor or Wiring harness failed) :cry: So..I've decided to bypass it becuase : a. "Most" Det damage is done above 3k, but the stock sensor only works under 3k its usefullness is limited. b. I always run Optimax. (So less likely to ever get Detonation) c. Im on stock boost( So less likely to ever get Detonation) d. I cant afford the massive job of having the det sensor replaced e. Will get it replaced if I ever need an engine out job done. So following these instructions : http://zhome.com/ZCMnL/PICS/detonationSensor/detonationSensor.html I need a 1 megohm resistor. Not knowing sod-all about resistors, I'm Looking on Maplin.co.uk but Im not sure what Im looking for. :headvswal is a 1m† Low Noise metal film High Voltage Resistor what I need ? (does m† mean megaohm?) :rolleyes: or can somebody who is in the know point me at the right one here : http://www.maplin.co.uk/search.aspx?criteria=resistor&menu=3&doy=23m2 Cheers :D
Cheers :D
