Camber correction arm length
Just got some adjustable camber arms and a gauge so I can set them.
Anyone who's done it (or used the shims) tell me roughly what length / spacer size they used as a starting point?
Was thinking with the arms being a bit shorter, the dynamic camber change is going to be greater, so probably best to aim for the lower side of the spec.
i just lined mine up with the old arms using the bolts, then just made them a touch longer.
they are fairly easy to adjust in situ.
