Turbo options.
On standard internal's what options would i have for turbo upgrade. TD04/05s seem popular but what about hks apex'i or blitz?
Nick, i'm having a special on some wicked tubs next week ;) get in touch if your interested :)
I'll call you when i finish work mate. I'm just looking at options at the moment as i've blown the head gaskets again and i still want to get those injectors!
No probs Nick i'll be on my mobile all day.
:hyper:25 psi:hyper: sound ok to you
Cant run that on standard internals like, but these tubs would see you through into the future.
Hi Chris
How laggy are they mate ? i am looking to get about 400rwhp when all is done
im just starting to collect bits and pieces now , The stoppies are allready sorted so thats a plus point when it comes to making it go quicker , im aiming for a more linear tourque curve as oposed to big BHP
Steve,
You will probably want our stage I if you are aiming for 400 BHP as these stage II's will produce 500-550 BHP
Surely i'd need an FMIC to run anything over 8 psi though? I'll end up sucking the intercoolers into the turbo's........ Which could be interesting
Why a FMIC at 8psi ? to see the benefits of the tubs, you would need
Injectors
Intercoolers
Forged Pistons
ECU Re-map
Then and only then could you get the kinda figures the tubs can produce :)
Just thinking of a/r rating i'm guessing that there would put out the same power at 8 psi as stock tubs at 1 bar. I was told over a bar uprated intercoolerr were neede
uprated sidemounts will be fine for that sort of power. FMIC's are for big HP or looks ;)
Dont you dare, you kow Im skint.....
500 550 BHP ....................wheres my wallet .......seriously chris drop me a PM with prices mate im thinking on a different track now ...........550 BHP sounds fun .....
Steve,
Specs on the tubs here http://www.300-zx.co.uk/product_info.php?cPath=28&products_id=117
The special will see £250 off those prices, further discounts if buying pistons head gaskets intercoolers etc..........
There really is no better time to buy.
That would equate to 410 to 440 RWHP which is scarey power and will need the HICAS elliminated, an uprated clutch, better coolers, bigger injectors, better pistons, Decat system, Widebandlamber sensor kit and software da da da.
Take my advice get someone to give you a blast in a car with that kind of setup then look at the cost and see if you really need it. GET JD to give you a blast in his. JD got 370 RWHP out of his car competely on stock internals. Just a chip, injectors, boost controler and Sidepod coolers. I can tell you it is raged every day and no problems.
PS Though if your going to go for it then these are the mutts :D
Your not wrong :nana2:
Paul yours will be with you on Monday :nana2:
