who has more Z bits in the spare room than on the z??
Since my Z has been off the road I have been collecting bits ready to go on, but I just havent the time to fit it all, speaking to others it seems the case is the same so a poll should be done :smash: ( hows it done :D )
how much Z stuff is in the spare room 37 members have voted
  1. 1. how much Z stuff is in the spare room
    • 0-100quids worth
      18%
      7
    • 100-500quid worth
      24%
      9
    • 500-1000quid worth
      35%
      13
    • too scared to work it out
      21%
      8
I only have a couple of bits lying around but its building up slowly. most of it is bits I have removed that arent going back on.
I should try and sell them really but i cant be ar*ed.
Currently to fit:
Replacement glovebox lid
Replacement clock
Replacement electric aerial
Replacement fan
Greddy boot spoiler (April at PPS)
OEM splashguards (April at PPS)
Headlight Panel (April at PPS)
Oh the delights of ZX ownership
Sitting waited to be fitted (i know it`s not a Z but same thing!!)
Garret N1 Tubs
HKS cams and pulleys
HKS twin plate clutch
Down pipes and Decat pipe
Injectors
Fuel Pump and Regulator
Apexi Power FC
Apexi AVC-r
HKS CAMP system
Hard Pipe Kit
Think thats it.
Bob
Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots n Lots etc
And ive just put half of it in my boot!! :)
Here goes
Unorthodox racing pully set
twin Trust airfilters
Polished plenum, balence bar, water pipes , CAS,
Polished howe rad
new ECU harness
Nismo 555's
jwt 530bb's with split down pipes
wiseco 88mm forged pistons and rebored block
series 2 ptu
24 new lifters
new oil pump and filter
gasket set
rad pipe kit
front mount intercooler
ported and polished heads
head bolts
fidanza lightened flywheel
6 puck clutch
uprated pivot ball
braided clutch servo line
new o2 sensors
new bigend and main bearings
usual 60k service bits
polished fues box covers
polished powersteering pot
apexi avc-r boost controller
hyperflex bush kit
tein suspension kit
2x 15" kicker L5 solabaric subwoofers
Nitrous oxide
flamer kit
braided fuel line kit
(stillen) HICAS removal bar
new fuel lines
think im going to need some time off work to fit it all, def all part of the fun I dont want to work out how much it all sets me back! at the end of the day i'll only piss it up the wall if I did'nt have the 300 :smash:
2 jl audio subs
2 rockford amps
loads of wire
apexi avc-r
iridium plugs
veilside rear bumper
lambo rear lights
de cat pipes
tv screens
ps 2
steering rack
and i want it all done for summer........(yea right :xxx: )
Here goes
Polished howe rad
new ECU harness
Nismo 555's
series 2 ptu
24 new lifters
gasket set
rad pipe kit
head bolts
6 puck clutch
uprated pivot ball
new o2 sensors
hyperflex bush kit
tein suspension kit
Nitrous oxide
flamer kit
new fuel lines
won the lotto or something LOL
TO GO ON
sgp lightened crank pulley&belts
amp
6x9s
18"azevs alloys
sat nav :D
engine bling
respray in 1month
im now officially skint after this little lot
I wish although the spec would be better than that if I did ;)
Just been giving the creditcard a good pounding + I have the added bonus of not having to pay for house and all the stuff that goes with it (still living with me parents)
Profec b II boost controller
triple a-pillar
Auto Meter boost, water temp and oil pressure gauges
set of LEDs
Samco vacuum hoses
rear strut brace
Smithy top rad pipe
new 02 sensors
I think that's about it...
Well I'm asuming that Garage counts just the same and I've got a few grands worth and everything on my rides is fitted. I could almost build a new car, 1 manual gearbox, clutch, flywheel, diff TT, Diff NA, rear subframe NA, Prop TT auto, prop NA manual, Anto box, Torque converter, Set standar UK wheels, Set of 18" split rims (in need of refurb)
Clocks, Guages, Bonnett, Targas, Spoiler Brakes, springs and shocks, Coolers, Short shift New, TT engine, Turbo's, HICAS eliminator SE and loads more big time for Ebay I think.
P.S So as not to disappoint Greg.
Well it all started a long time ago when I was knee high to a grass hopper and :smash: :rofl: ;)
LMAO :D
Not too bad..
Porterfield Carbon Kevlar brake pads
Jap Spec front fogs/side lights
Outlander HID kit
PCV Valves and Hoses
2 x 12" Subs and 1100W Amp
Razo Gear Lever
Steve :)
'93 UK TT Manual
where's the option for 5-10k :x: I have to use one of the bedrooms as a stock room , will be glad when the stock room gets built in the new unit
Thats the dont make me work it out bit :D
Heres mine
viper rear spioler
Full Poly bush kit (upper and lower)
Uprated oil cooler
Nismo Front light panel
Indiglow dail fronts
clear side repeaters
prop shaft bearing
Carbon dail surrond
fuse for my boost controller
  • 1 year later...
lol, half that stuff in my reply 2 years ago was junk!
until recently it was JWT flywheel, SGP u/d pulley, RPS clutch, shortshifter. but now theyve all found a new home ;) ;)
aye one mans junk another mans treasure :)
