My Ariel...
Its started clicking when going up, does this mean i need to replace, or can i just repair it? i think it was caused by a build up of dirt ,as when i sprayed wd40 on it to free it one day the dirt was unbelievabl
If it's clicking, it's probably the teeth in the drive mechanism slipping, or the plastic drive may be broken. You can buy just the aerial and drive without the whole motor unit, if it is broken.
Thanks for your help,does sound like teeth slipping,where can i buy the aerial and drive.
gets abit annoying waiting for it to stop clicking away :)
Hi! You can get the drive and aerial from any dealership - probably find a cheaper source from the US but they aren't that expensive. It's a bit of a pain in the a** to change though - you have to remove it from within the boot, and remove a small grubscrew from the drive body so you can slide the old aerial out from its sleeve. All straightforward when you see it though. ;-)
Taking a perfect one out of mine on Monday if you need another
How much do you want for it mate :)
Give us a tenner plus post :)
thanks chris how do i ring you with details or e-mail
Drop me an email on the address below :)
Ive sent you an e-mail. :)
Ditto ;)
