Serious missfire after 2500rpm!
:confused: car is running like a pig! will run under 2500 rpm
above that is like its running on 2 pots.
I think its vacuum fault but not shure, as its when
the turbos are coming in as if no petrol?
any ideas would be helpful
thanks in advance
allan
Done an ECU check?
Sounds like MAS problem.
PTU imo ,
do you have a spare to swop it out with ?? they can be repaired at home but its not too easy , try doing a search on the FAQ or tech advice about the repair method
Steve
yep, certainly sounds like the AFM as a faulty AFM will not let you rev past 2.5k.
Vijay
dirty connections on the air flow meter, pull off the connector and clean them all up and then refit, do a ecu reset and all should be fine !!!
Checked out today and is ....................
AFM fault. Replaced unit and all is well
Thanks for help :) :)
